Dash cam recommendations.
Kithmo
Distinguished Member
Solutions
Rotherham
Anyone recommend a good dash cam ?
It's about 5 years since I bought my old Dodd 460W dashcam which is still in my Prius. It was one of the best available at the time, it's just HD 1080p but the footage is amazing, especially night time, you can see every number plate and such.
I've looked online and there seems to be an endless choice of HD, 2K and 4K cameras and I was wondering if it was worth going to a higher resolution going on the quality of the Dodd HD one I have.
Are there any other advances in technology from 5 years ago that are a must have thing in dash cams now ?
I have the Nextbase 522 with the added rear camera. Fairly simple to fit and seem to work well 6k miles in. Virtually unseen by the driver.
What's the add on rear camera view like, does it see the cars behind ok, or does it mostly see the interior of the car ?
"Tom's Man Shed" Youtube channel has a very informative review of the VIOFO A129 PRO DUO (dash and rear cam) plus a full installation into his MG ZS EV. Tom presents a good argument for going the 4K way. URL below:
I would recommend the Roav C1 Pro (by Anker). You can fetch videos via the app using built-in WiFi on the device.
It attaches to the rear screen (I put it top and centre) and sees the cars behind. Just need to route the cable to the front. Card records both front and rear views.
I didn't fancy having to thread cables all the way to the back and I didn't want just a view of the interior, so I've gone for the Nextbase 522W with the rear view plug in add on rather than the rear window camera.
The rear view bit that attaches to the side of the front camera has a telephoto lens with a narrower field of vision and shows a view like the rear view mirror, which is better than no rear view.
I may get the one that attaches to the rear window later if I don't like this one and I pluck up enough courage to start pulling off bits of trim and threading wires all the way to the back.
Routing the cable was relatively straightforward. Trickiest bit was feeding it through the existing rubber cable routes from the boot lid to the car but it does fit, then just went along the headlining. There is a plastic cover that pops off from the inside top center of the boot lid giving decent access there too and just above where I fitted the camera to the glass.
