Vingnut
- Nov 20, 2022
- Solutions
- 1
- Location
- Haram, Ålesund
- MG4 Trophy LR
Guess it`s this one:
Was it the video I made? sounds like my instructions the silicone grease can get messy but it really helps.
With the cigarette lighter you don't have parking modeI made things very easy by not going into the difficult to access fuse box, but used the cigarette lighter under the phone shelf (MG4 2023 LR) the shelf hides everything and the plug in 12v adaptor is unseen, so why delve into the fuses at all, I could understand it if the 12v socket was in full view as with my previous (Hyundai) cars, but the Hyundai fuses were easily accessible, MG could make things a lot more user friendly by improving the fuse access.
Works in mine, with a Roav dash cam. It has a battery that charges whilst driving, and then is able to record any incidents whilst parked.With the cigarette lighter you don't have parking mode
For 1 year I have been using a Thinkware T700 in parking mode, without using external batteries. It is set to turn off after X hours or if the 12V battery voltage drops. It works very well. But if you feel good with the battery, keep going ?Works in mine, with a Roav dash cam. It has a battery that charges whilst driving, and then is able to record any incidents whilst parked.
Yeah, I bought a cheap Alfawise dashcam around 5 years ago and it's just plugged into the 12V port and I unplug it when parked as the port is always 'live' and it would eventually drain the 12V car battery if left plugged in whilst parked or garaged.For 1 year I have been using a Thinkware T700 in parking mode, without using external batteries. It is set to turn off after X hours or if the 12v battery voltage drops. It works very well. But if you feel good with the battery, keep going ?
Hi, the fuses that I used are micro 3 for the switched 12V, like these ones if you need to connect to permanent 12V, then you'll need the micro 2 also.
I attached 2 pictures for the location of the fuse box, as usually there are taken from too close to see where it is for new users. My car is an LHD. For RHD cars, it is at the opposite side.
Fuses for 12V switched connection (micro 3):
Fuses for permanent 12V connection (micro 2):
View attachment 23419View attachment 23420
There are hundreds on Amazon - search for "short usb cable", starting at 150mm / 6 inches.I've looked through these dashcam threads but I cant find what I'm after. Anyone know where I can get one of those short power leads that go from behind the rear view mirror to the dashcam.
I think he means behind the rear view mirror; i.e. plug in to the power source that supplies the cabin lights. I don't think there's anything readily available, except maybe on AliExpress. I suppose you could fit mini-taps into the wiring up there and maybe terminate that with a USB plug.There are hundreds on Amazon - search for "short usb cable", starting at 150mm / 6 inches.
His profile lists a ZS EV, which I think already has that from the factory?I think he means behind the rear view mirror; i.e. plug in to the power source that supplies the cabin lights. I don't think there's anything readily available, except maybe on AliExpress. I suppose you could fit mini-taps into the wiring up there and maybe terminate that with a USB plug.
I just went by the fact he posted in a sub-board of the MG4 board.His profile lists a ZS EV, which I think already has that from the factory?
I just went by the fact he posted in a sub-board of the MG4 board.![]()
