KasEV
Banned
- Apr 10, 2020
- Manchester
Folks,
I am with @Frank on this issue.
Yes, I agree with all of you that where necessary precautions should be taken so I have nothing against having a jumpstarter. But I personally will not deem a 12VB jumpstarter a very necessary precaution for a modern EV. l will save the money for something else.
Far easier and straightforward to plug in overnight or charge at least once a week. If you are doing that and yet getting a flat 12VB then there is something wrong with your electrics and a jumpstarter is not the solution. You need your electrics checked.
Modern EVs are wired to ensure flat 12VB does not occur when the EV is in use even if use is infrequent to a total of I hour driving a week. The manufacturer has otherwise given advice on what to do when the EV will not be used for a long time. That is to disarm the negative pole of the 12VB until you are ready to use it. When you are ready to use the ZS EV you reconnect the 12VB negative pole and charge the car and off you go.
I think we often just complicate things for ourselves when just following the simple manufacturers instructions is better.
