DIY V2L cable "waterproof"? Or
How do you wire this to the 3 pin sockets, which only have brown blue and yellow wires. The Type 2 seems to have more than 3 colours of wires as per photo. Thanks
Note that the resistor shown was determined by an electronics expert using trial and error - it has since been released by MG that the resistor should be 2K Ohms, limiting discharge to 2.2kW
I would say get an MG one to use it safely. What are you going to use it for?
Maybe the electric motor in the washing machine draws too much current the moment you switch it on? The stationary motor draws much higher inrush currents than motors that are already running.
Another explanation would be that the voltage and current of the motor are not in phase (due to the inductive nature of the motor). Therefore, it may be consuming more apparent power than real power.
My guess is inrush currents. Some washing machines have a smoother start-up of the motor that does not consume as much power in the initial phase.
Ditto to @crunchy's comments. Washing machine motors are a very reactive load, especially during motor start. The inverter in the MG4 won't tolerate the poor power factor and surge current involved.
    Votes: 942 77.6%
