Does anybody recognize this one? (MG Clive's MG4)
MG Clive
North Yorkshire
MG4 XPOWER
If there's no fix for this vibration problem, won't they all have it?
Nope. It's sheer pot luck! A long test drive is needed, including a decent motorway drive. That's essential. 🙂👍
One good thing though, it's got a Black badge, they are definitely, faster! 😉😀
No the problem seems to vary in intensity from car to car (so the assumption is variable tolerances on the parts causing the issue). I have driven one with zero vibrations but it seems a majority of them have if built between summer 23 & Dec 23, hence test drive essential.
As above no one seems to know for sure. Newer built ones after a certain date (built after Nov 23?) may not have it, some older ones seem to have it quite bad and some only minor.
For me, cruising at around 67-70mph, uphill and on a slight left hand curve is always the worst and will always bring on the vibe through the steering wheel. The better (smoother) the road surface the more noticeable the vibe. Apart from that mine's pretty minor.
If you can test drive it then you really have no excuse to not do so thoroughly at the above speeds for a good length of time. You are in a very lucky position to do so 😉👍.
Given the black badge mod someone must have sold that car quite quickly. If you mod a car you usually intend on keeping it longer than 6 months IMHO.
Nice colour btw 😉
Just a thought , they may take you for a test drive ( not allowing you to drive ? ) are the vibes detectable as a passenger? at the speeds and conditions they normally occur . Question , for qualifying members and spouses.
Then you wouldn't, entertain it. End of.
