Bricktop X PWR
Distinguished Member
- Aug 30, 2023
- Age
- 57
- Location
- West Wales
- MG4 XPOWER
Mods, I know there are plenty of Charging Flap related Debacles, but I've started afresh as I haven't seen this information before.
Please move, if this has been covered elsewhere.
After last year's faffing and Charging Flap related shenanigans, I got my hair off last night when it wouldn't open.
I needed to plug in and charge my household battery bank.
Quite by accident (Ahem) I managed to pull off the painted cover to expose the Charging Flap itself.
This was preluded by several bowls of quite warm water hoping to free it off.
Anyway, I have since discovered that you can open the flap with a T45 bit.
This removes the pin from the door which in-turn means you can access the port itself.
To be clear, you rotate the pin, then pull the flap open.
The pin, if frozen, will likely stay in place, but you can still open the flap.
You must of course remove the painted flap cover first.
This is child's play.......
If the flap is shut, then you simply get a trim tool into the gap and pull towards you, starting at the Top Right Corner.
The painted cover has 4 tabs that slide into a channels on the Charging Flap.
I didn't take a picture (soz) but it is obvious when you see it.
I am now carrying, as part of my emergency tool kit, a jump pack, a trim tool and a T45 bit.
There will be nothing worse than rocking up to a charger, desperate for electrons and not being able to open the flap without outside assistance.
If you ever need to remove the painted cover, but you flap is operational, then pull this plastic tang towards you whilst sliding off the cover.
Please note the emergency release cable is purely to release a stuck charging cable and not to open the door.
