Glove Box Removal?
crispy77
London
Can someone help me with getting the glove box out so I can get to the speaker wiring? I managed to get the retainer string off and then got stuck. Can pop the bottom left out but the right seems stuck fast
If anyones got a video that would be amazing
Cheers
Cheers
The main speakers are normally in the door(s) - why would you need access to the wire(s) via the glove box?
It's a LHD high spec model with 6 speakers. In my Excite (51kWh), the 4 speaker version, the audio unit is under the center console. Easy to access, by removing the side panel in the footwell.
You just squeeze it in either side at the top-rear. It will then hinge fully forward and you can pull the hinge pins out of the retainers.
The audio unit is mounted in a different position depending on the spec level. That's bonkers. Are the audio units indentical for the different specs?
No, I guess. My one is black and in a different location, I couldn't find any identification on it. Also it has one less connector.
I wonder if this is a difference depending on model year rather than spec, as I'm guessing you have a MY23, not MY22. I think those withe SE models that have performed speaker upgrades are MY22 mostly?
    Votes: 1,052 77.9%
    Votes: 204 15.1%
