Rolfe
Moderator
- Apr 10, 2023
- Location
- West Linton, Scotland
- MG4
Thanks.
The 12v is charged by the HV battery when it is in ready mode (or driving) or if you are charging. It is not charged when the car is turned off and not plugged in. It should be fine if left for a few weeks just like any car. The app apparently wakes the car up when it scans so using the 12v slightly, so maybe it's best not to keep checking it on the app if you are not using for some time. But if your 12v is in good condition and you don't have anything that can drain it switched on then it should be fine to leave it for a few weeks as you would any other car.Could you elaborate on that last bit? Sorry to be so ignorant but I've only had the car a couple of weeks. What happens when you check the car with the app, and if that does drain something, will it all be replenished next time the car is driven?
Yep, even when the car is off! We left ours for a few weeks and checking on the app I could see the 12v battery dropping down and then a couple of days later it was back up again. Main battery dropped by 1 or 2 % but the 12v was absolutely fine when we went back to it.Not when the car is off though.
Are you saying you used your MG4's 12V battery to jump start your Stag?I understand the 12v Battery is only used to power up the main console and hence open the software and screens so other main systems can be activated. When others have had problems with 12v flat battery the AA have just jumped charged with another 12V battery to get the car to wake up. Once its energised the car is good to go.
An ICE car requires a lot of starting current from the battery to overcome the friction and momentum to turn the engine over so the poissible burn outs in reviews may be on starting a large engine. However EV's dont have high torque starter motors and like I say the 12v battery is just mainly to get the cars main systems activated.
I have used the one I got to start my Triumph Stag 3.0 litre V8 and was fine.
Yes, my ICE car does that occasionally. I just give it a bit of welly, and it unsticks (and shoots forward, of course . . . ) I wish it was possible to leave it in park without the handbrake on, but it's too modernAnd then get help for a wheel that wouldn't turn due to the brakes binding.
I've just got back after leaving our car for 6 weeks and it was fine. It took a bit longer than usual for everything to fire up and READY appear so I guess it had shut itself down pretty well - I'd done nothing other than lock the car. The 12V battery is showing 12.4V in the app. The main battery had dropped about 5% in that time. I'd left it just under 60% charged.On page 291 of the MG4 Manual it says
'If vehicle will not be used for an extended period (more than 1 month), it is recommended to disconnect the battery negative terminal clamping pile head. Make sure that the vehicle power system has been turned off before connecting or disconnecting the negative battery cable'.
Presumably that means it is OK to leave the battery connected when away for just 2 or 3 weeks.
Good, it was just rousing itself from a deep sleep. That's how it should work.I've just got back after leaving our car for 6 weeks and it was fine. It took a bit longer than usual for everything to fire up and READY appear so I guess it had shut itself down pretty well - I'd done nothing other than lock the car. The 12V battery is showing 12.4V in the app. The main battery had dropped about 5% in that time. I'd left it just under 60% charged.
Thanks! Mallorca in January is lovelylLeft my Trophy in the airport car park for 7 days on 45% and when I got back it was still on 45% and I had no problems getting moving.
This was in January with o/s temperatures of -3c to +5c
What I did like was that I could check it's status from the beach in Mallorca from my phone
Ta!You can remote unlock/lock the car via the app.
You are not supposed to leave the car for long periods with a fully charged 400v battery. Apparently degrades it'Don't leave it with a full battery?' Sorry don't understand. Why? What level of battery is good? I'd normally leave it at the usual 80%. Yes - saw those power bank things. Sound a good idea.
