Heater on When Charging
Does the bms update explain the difference?
I don’t believe so as with the new BMS update the minute you plug in, give or take a few seconds the charging port will lock and the car chargers with or without the car being locked, similar to a rapid charge.
Mine will only charge when the car is locked..I suspect your is the same.
Does it matter if the alarm is armed when you're sat in the car with the doors locked, does it have internal movement (ultrasonic) sensors ?
That’s a very good point as I don’t believe it does..point well made.
