Help calculating energy usage to charge car
Shengis
Perthshire, Scotland
Day two of MG4 ownership. So far so good, except for the double bulge!
I’ve only got a granny charger available meantime until I get a proper charger installed early Jan.
Yesterday I charged the car from 70% up to 100% through the night.
I also got a smart meter installed last night so that I can move to an EV tariff for cheaper overnight charging.
As a result with the new meter starting at zero, I’ve noticed that between 18:00 yesterday and now, we’ve used 37 units. This sounds a lot as think we average about 10 kWh a day based on previous months.
By my calculations if I charged the 51 kWh battery from 70 to 100 that should be about 15-16 kWh, yes? I just want to check if this is correct.
Also, the car stopped being charged at 100% obviously, however the plug was still switched on at the wall till I was up in the morning. Would this account for the extra high energy usage or would the granny charger stop using electric when the car was full?
Don’t forget to account for losses, charging is only something like 90% efficient. So I’d expect something like 17-18kWh for that charge.
That suggests with your daily usage that you still used maybe 9kWh than you expected.
No more electricity will be drawn when the car is full, it has nowhere to go.
Were there other appliances on that were unusual? How confident are you in 10kWh per day? That’s not a lot for a house of a decent size or a family (there are 2 of us and 2 cats and we average 17kWh per day).
I have a smart wall box with an app that tells me kWh usage for each charge session. Bear in mind that this is total supplied by the wall box; not the total stored in the car. (There are charging losses, and these are proportionately higher from a low power "granny" charger than from a 7kW wall box ... there are fixed losses and variable losses; fixed losses apply regardless of the power source, therefore these are a much higher percentage of total losses when using a "granny" charger).
Total efficiency from my 7kW wall box is 90%+ ... this means to store 50kWh in my car I'd actually use about 55.5kWh of electricity.
Total efficiency from a "granny" charger may only be, for example, 70% ... so 30% into the car (15.4kWh) may actually be 21.7kWh from your supply
I’ll be honest, it’s not something I normally keep an eye on at all, however on the OVO Energy app it gives me my monthly usage which is typically between 290 and 330 kWh so with roughly 30 days in a month that’s where I’m getting the 10 a day from.
I hope I’m wrong because if this month’s bill is bigger my wife will murder me and bury me in the back garden. Since I promised her savings with this new car! ?
Are granny chargers that inefficient? I did not know that.
Yep, I see what you’re saying. The quicker I get on an EV tariff with off peak rates the better then!!
Of course your leccy bill will go up ... but your 3rd party fuel bill (petrol/diesel) will come down. The key is that the leccy increase is (hopefully) much less than the fuel decrease. :)
If she does, can I have your car? ?
This thread suggested ~80% efficiency ... my 70% was just a stab in the dark, but granny leads are less efficient than wall boxes.
    Votes: 936 77.6%
