Jomarkh
Distinguished Member
- Apr 5, 2021
- Location
- Southampton
- MG5 Excite
The car is the bit that does the charging so will pull up to the limit of the EVSE or the car itself.
Does the Easter or the Simpson & partners support OCPP? As that's an openbackend standard that means you can move round which software platform you run your charger from.Dno called back and said they have no record of what size cut out fuse I currently have but would usually do a site visit when the evse is being installed. I asked would it cost anything to upgrade and the lady said she thinks it should be free as it's an upgrade that is contributing to reducing the carbon footprint, just wish I'd taken down her name for reference.
I just can't get over the aesthetics of the pod point so I'm swinging towards the easee one and the Simpson & Partners Home 7 plus has been brought to my attention which looks even nicer. Only concern with the Simpson & Partners evse is will they still be around in several years time or wrap up and move on like what they seemed to have done with the Anderson evse's
I'd be lying if I said I knew, never heard of it but I've only been looking into evse's for a few daysDoes the Easter or the Simpson & partners support OCPP? As that's an openbackend standard that means you can move round which software platform you run your charger from.
I know wallbox, and Rolex support it
Covered this here:"The present fuse installed is rated at 60 Amps, but would it actually fail / blow right at 60 Amps, or is there any margin above this rating value ?".
Have you looked at the Hypervolt unit by any chance ?.Dno called back and said they have no record of what size cut out fuse I currently have but would usually do a site visit when the evse is being installed. I asked would it cost anything to upgrade and the lady said she thinks it should be free as it's an upgrade that is contributing to reducing the carbon footprint, just wish I'd taken down her name for reference.
Don't pull the cutout fuse, you're not permitted unless authorised by the DNO or it is a life or death situation.Have you looked at the Hypervolt unit by any chance ?.
My local EV installer paid a visit to both mine and my brothers properties first.
He carried out a quick survey of our electrical set up before quoting on the EV install.
Recommending a gas and water ( CPC ) earth bonding cable size upgrade on our equipment, which was a "paid for" upgraded for us to settle.
The survey could be used to correctly access the suitability of the main cut out fuse and then the installer could make the request directly to the DNO to carry out the rework.
Or he may install the wall box and then notify the DNO of his findings on the rating of the main cut out fuse.
Reducing the max load the wall box can pull, until the main fuse has been upgraded ?.
I totally agree @Ayoull !.Don't pull the cutout fuse, you're not permitted unless authorised by the DNO or it is a life or death situation.
If you saw the PPE you're supposed to wear for removing a cut out fuse you'd understand why, the issue is that the cut out can fail and arc.I totally agree @Ayoull !.
I have witnessed this being done by professional / qualified staff, but under NO circumstances should anybody even consider for a second, consider it !.
It is illegal at best and deadly at the worst !.
Even a qualified spark should be contacting the owners energy provider to have their support team come out to carry out the disconnect / reconnect of the main cut out fuse.
Imagine as a spark, you and your lads are working on a row of 5 houses that all had different energy providers, you then have to contact them one by one, to carry out the work !.
Before the sparks can safely carry out their work.
Its just not practical and therefore gets omitted.
They have been fighting for permission to do this for a long time and it has recently relaxed slightly, for expanding a team for each energy provider, but been rejected once AGAIN for qualified sparks is my understanding !.
I know it is a much debated issue, but personally I think it is crazy system myself.
Here is a recent video that explains the rule changes that come into effect from summer 2023.
Advance the video to 03.35 minutes to pick up on the story.
I did but it was just a little too big for the wall where I want it installingHave you looked at the Hypervolt unit by any chance ?.
I was really lucky enough to have witnessed a complete service head replacement by my local DNO only last year.If you saw the PPE you're supposed to wear for removing a cut out fuse you'd understand why, the issue is that the cut out can fail and arc.
Was you looking to site it, on that pillar of brick work between the front door and the garage ?.I did but it was just a little too big for the wall where I want it installing
The door to the right of the brickwork is to a full length lean to and the CU is around 4.5m along that wall as shown in the photo with the lean to door open. Excuse the clutter ?Was you looking to site it, on that pillar of brick work between the front door and the garage ?.
If so, it will fit there with no problem I think.
Where is your CU ( fuse box / meter ) located, in relation to that column of brick work @jpk ?.
It will fit if you move the plant?I did but it was just a little too big for the wall where I want it installing
I checked their website & if they sold an untethered they were going to be my first choice in the end if for nothing other than the led party mode ?It will fit if you move the plant?
It's the Energy Networks Association which is the DNO association that overseas all DNO engineering recommendations and best codes of practice, and also do all the type testing to make sure they're safe to use.he's sent the ENA (I don't know what that is!).
