How to put car in neutral for towing if battery is dead
coff33
Australia
MG4 SE SR
Petrol cars let you override the gear selector, some of them have a place for you to stick a screwdriver for example. How to do this in MG4?
Its good to know this in case you are stuck in the middle of the road and need to push the car to the shoulder for safety.
There is a neutral option on the gear selector.
In the quick ownership guide it says:
"When pushing or towing the vehicle for temporary situation, the driver's side seat belt should be inserted into the lock and maintained in the inserted state, and then place the electric drive transmission in Neutral in order to release the EPB , otherwise the vehicle may be damaged."
Are you concerned that you need to have someone sat in the seat, so a person on their own would not be able to push the car?
It' not an obvious thing to most owners that the car has to be in ready mode but neutral gear (if I'm right and you do indeed need to be in ready mode to select neutral). I think that's because of the permanent magnet motor, which will generate voltage when the drive wheels are turning, and even if the car is off, the IGBT free-wheel diodes will conduct and cause the big capacitors to charge up, possibly quickly enough to cause damage. Worse than that, above a certain speed, this voltage is too high for the electronics to withstand; this will cause serious and expensive damage, as well as possibly causing a drag on the wheels and possibly a fire hazard.
It seems to me that in neutral, the IGBTs will actually have to be fired up and producing pulses to actively counter the magnet's field (i.e. initiate field weakening), in order to keep the voltage generated by the motor at an acceptable level. If I'm right, then when in neutral, an EV is far from inactive (as an ICE car in neutral gear would be).
Cars like Teslas that use induction motors may avoid this, as induction motors don't have permanent magnets. But it's possible to use an induction motor as a generator, so it's unclear to me whether it's really different as far as neutral "gear" is concerned. It may be that residual magnetism in the induction motor's rotor may be enough to cause problems, although it seems unlikely as I type this.
Edit: To avoid all this, you would normally tow an EV such that the drive wheels are off the ground. In an AWD EV, this may not be possible, as all wheels are drive wheels. So you may need a tilt tray for an AWD EV.
    Votes: 911 77.7%
    Votes: 171 14.6%
    Votes: 90 7.7%
