How to reset the voice command in car
Julesdeno
Bedworth
MG4 SE SR
Please help.
When I use voice command on phone, ie: Dial Dene the phone voice reports an alternative contact. Ive tried restarting unit & unpairing iphone but simply goes back to the random dialling
I assume you are using the MG voice system to do this. In which case its useless for dialling contacts as I have found out myself. Your best bet is to connect and use Apple Car Play. I believe if you long press the 'voice' button on the steering wheel, it will bring up Siri... it does so with Android Auto anyway.
I thought the MG system only works if android auto (AA) is connected, if you press the button on the steering wheel without AA on it displays a message to say you need to connect it. Most of the time it fails anyway and says it needs to try again, and even if it works most of the time it dials the wrong numbers
    Votes: 911 77.7%
    Votes: 171 14.6%
    Votes: 90 7.7%
