Gomev
Distinguished Member
Guess-O-Meter - miles range left.What is GOM?
Had a response from the Dealership. They say another BMS update, previous update done 3 weeks ago, is being applied. This will require 325 hours of either driving or charging. I have asked which one. If driving this would take me a year to achieve. If charging with my limited range and using the Granny Charger this could be achieved in about 8-10 weeks.Hi Folks,
I beg to differ about the quality of the GOM in the ZS EV.
In my opinion it is one of the best on the market. This is the opinion also of several professional reviewers including B Nyland from Norway.
The ZS EV GOM does exactly what it is designed to do.
I will recommend to all those who feel their GOM is not working right to have it checked.
As for this simple multiplication that is persistently being pushed down our throats please forget it. The Current and Acummulated data does work on averages but the GOM is more complicated than that.
These are the official MG data:
What is your voltage when fully charged to 100%?Had a response from the Dealership. They say another BMS update, previous update done 3 weeks ago, is being applied. This will require 325 hours of either driving or charging. I have asked which one. If driving this would take me a year to achieve. If charging with my limited range and using the Granny Charger this could be achieved in about 8-10 weeks.
All without any guarantee of a full resolution. All this leaves me very unsure whether to cut and run or not.
There’s lot of responses on here about equalization and bms updates. If you are struggling, I would strongly suggest that you firmly push back to the dealer and tell them to sort it out. From what you say you can no longer use the car as intended due to significant loss of range. Tell them you are not prepared to accept the car in its current condition. That is not being unreasonable - it’s unacceptable to be expected to sort it out yourself and during that time suck up the consequences.Had a response from the Dealership. They say another BMS update, previous update done 3 weeks ago, is being applied. This will require 325 hours of either driving or charging. I have asked which one. If driving this would take me a year to achieve. If charging with my limited range and using the Granny Charger this could be achieved in about 8-10 weeks.
Full charge on eco 165 , 175 with heating control turned off.What is your voltage when fully charged to 100%?
Sorry I thought you meant mileage. Voltage 435Full charge on eco 165 , 175 with heating control turned off.
lol you've posted this on 3 different posts! And had the question answered several times!Yes I think you’re right. The dealer said 325 hours of battery charging would be required. Is that what you have heard?
Take the car to the dealer to sort out. Read the attachment, it states 'the option should be offered to the customer for them to leave the vehicle for continuous charging at the dealership'There’s lot of responses on here about equalization and bms updates. If you are struggling, I would strongly suggest that you firmly push back to the dealer and tell them to sort it out. From what you say you can no longer use the car as intended due to significant loss of range. Tell them you are not prepared to accept the car in its current condition. That is not being unreasonable - it’s unacceptable to be expected to sort it out yourself and during that time suck up the consequences.
The MG ZS cell balancing process dealer information sheet I attached to my earlier post does not instill me with confidence in MG. They contradict themselves ie. '6 If the average is above 100mV and below 450mV' and in '7 If the average is above 450mV... until the cell balance is below 100mV.Very interesting that just leaving the car in Ready mode after fully charging does the balancing as well.
Not many people knew that![]()
That's great info to get a copy of that.Take the car to the dealer to sort out. Read the attachment, it states 'the option should be offered to the customer for them to leave the vehicle for continuous charging at the dealership'
I wonder if @MilesperkWh could comment on this - this is the first time it has ever been mentioned that just leaving a car in Ready mode will rebalance the battery cell packs.Very interesting that just leaving the car in Ready mode after fully charging does the balancing as well.
I was thinking the 1mV per hour, relates to each cell. So each of the cells within the 9 cell packs can have their min/max moved by 1mV per hour.Reading those notes is interesting - thank you. I thought cell balancing only occurred after a full charge. It seems that if the car is left standing in ready mode the cells also balance and that this is how dealers are told to balance cells. Also each 0.001v imbalance takes 1hr - so 1000hrs to get 1 volt?
That said it doesn’t change much as far as getting the car sorted - if it is that John genuinely wants to sort the car and not just repeat posts on various threads getting the same responses - then get it back to the dealer for them to sort it out. If of course he has had enough of the car that’s another matter and it may be time to move on. Either way continually asking the same questions won’t get the car sorted.
