iSmart app.....Do I REALLY need it?
My dealer, installed the ismart app when I picked it up, 3 weeks ago. Not used it yet. And to be honest probably never will. ???
I cannot scan the QR code either. Tips would be great 🤞😊
You might be better posting your question on the MG ZS forum as the procedure is probably different to the MG4
Is phone already binded with the car? If you click on the user icon on the car home screen does it show you are logged in?
Can't even get as far as seeing the QR code on mine much less bind with it. The car just says it has no connection in spite of having a perfectly good signal.
It's nice getting into a warm car (Tesla's app works perfectly in comparison) but it's not the end of the world not having it on the MG. The car warms up inside and defrosts much faster than any ICE I've ever owned so having to sit on a heated seat for a few minutes before setting off isn't a huge issue. IMO it's one of those 'nice to have' things but I'm not going to lose any sleep over not using it.
Mine played up the other day, when I asked it to cool down. It just told me to try again later, but when I got to the car 5minutes later the aircon was on and car cool. And now when it connects it doesn't show state of charge or range. But vehicle status seems to work.
Ismart is not active in Türkiye, I cannot see the charge of my car without going to it. I get into a freezing cold car in cold weather. I wish it would work even if it was problematic.
You could go back to a dealership and get them to sort the connection out for you. It is a feature of the car and as such should work.
I've found the app to be really useful , both to warm up the car on cold days and to cool it on hot ones . I also use it to unlock the car at work when I've left something in the car but, but get to it only to find my keys are still in my desk!
Sounds like you need a software update - I needed an update and then everything worked, and don't apply the latest version automatically (I believe)
I would certainly miss the convenience things mentioned above - and also a quick check on tyre pressures before I head out (one thing less to do when in the car).
Bear in mind that the app shows the last-reported tyre pressures (i.e. the pressures before the car was last turned off), which may not be the same as the current actual tyre pressures.
    Votes: 933 77.6%
    Votes: 178 14.8%
    Votes: 91 7.6%
