Lovemyev
Distinguished Member
- Jan 23, 2021
- Location
- N.Wales ZS EV ( Gen 2 ).
Thanks for the tip !.This probably doesn't apply to the ZS but on the Prius, if the 12v was disconnected for any length of time or the windows went out of sync for any reason you had to initialise each of the windows physically as in press down and hold for 3 seconds after it reaches the bottom, then repeat for up again holding for 3 seconds.
I think it's worth a shot.
I have given it a go, but no joy.
It still reports the drivers window open ?.
Strangely, if any of the other windows are open, it does not report their condition at all.
The App is somehow frozen / convinced on a previous report, when the drivers window was slightly lift open ?.
All the other reported values from the App look fine, it’s just the side window conditions it is struggling to get correct - It’s really odd ?.
Not a major concern, but frustrating at the same time !.
Edit :- I have just noticed, if you disable the rear windows from the drivers door,
The LED light comes on in the switch ( indicating that they are now switched off ) but I can still open the rear windows !.
I can not disable the rear windows.
