Hi Eckmash,
We own two electric vehicles, one Mercedes A Class Hybrid 250e and a wonderful new MG ZS EV Exclusive in the same tri-colour Red as yours.
Our ROLEC Charging Point was installed through a Government Grant OLEV Saving Scheme by a Company called AMPEV who are based in Southport.
I am a qualified electrician and couldn't even buy the box from my wholesaler cheaper than what they installed it under the grant scheme, although I did require extra amour cabling due to the distance from the consumer unit to where the charger needed to go, so I installed that myself and they came along and terminated at both sides.
My house was built in 1924, so was wired with a TNS Electrical supply with a main fuse rated at 60amp.
AmpEV told me this must be increased to at least an 80amp rating, which after speaking with the area electricity supplier, this was done free of charge as the records showed the underground cabling was sufficient enough to handle a supply up to 80amps.
Most modern houses have a supply feed now up to 100amps so that may not be a problem if you live in a newer home than mine.
Here are the details for AMPEV and the available Grant Scheme:
Electric Vehicle Chargepoint Installation Specialists
ampev.co.uk
By the way, I have just checked the latest OLEV Government site as this was updated on the 4th December 2020 and the good news is that the MG ZS EV is now included on that list.
You can view the Government Grant EV Charger Information Site here:
Guidance for installers about the OZEV electric vehicle chargepoint and infrastructure grants
www.gov.uk
By the way, AMPEV did all the paperwork and applied for the grant on my behalf, just left everything to them.
Hope this helps.
Andy (Blackpool)
