jonney
- Feb 4, 2023
- Location
- Limerick, Ireland
- MG4 Trophy LR
I thought I'd post some details on LKA as I see a lot of people wondering why it's on by default, why MG wont turn it off and why some cars do turn it off permanently.
LKA is an ADAS feature made for one reason; NCAP points. The NCAP test cases are well defined scenarios that the car has to perform. There is no negative scoring for false activations (unless they occur during the scenarios) and the roads defined in the scenario are the ideal case.
You can see NCAP definitions here.
So why does it keep turning back on every power cycle? Because NCAP define that the default state for the feature is ON.
If MG change that then the vehicle would need to be recertified and would loose the points given for the feature.
Some people report that it turns off permanently, this is definitely a software error/oversight and when they get an update at service time this will be removed.
MG have this feature enabled because they are rewarded for it. Most manufacturers (especially budget) will take the minimum viable product that passes the NCAP tests.
The real failure is on NCAPs tests that are rewarding unsafe assistance features.
I work in ADAS software for another manufacturer.
Although I haven't been involved with LKA.
