Maj / Update the map
GuizmoFR
Meillonnas - France
Hello,
I tried to update my maps on my brand new MG eHS but it fail.
I used the NaviExtra Toolkit application for this. (I before plug the key to the car system and it initialize it)
Often it failed with a message "non compatible maps" and sometime, with other USB key, it reboot at 50% :/
My USB key is a 16Go no name model.
Regards,
Yes, I have an iPhone why ?
Just tried to update the Charging map only but failed with an non compatible data ... I will try to update the map first.
Ok
the MG nav system is very basic I use a carplay2air plug in to the usb and use Tom Tom which is a lot better and in proved the use of the entertainment system have a look on youtube.
i also used CarPlay on mon iPhone with Waze but I wanted to have my maps an up to date because the ones included are 2019 Q4 ... I only have 90 days to do this.
Hello,
Regards,
You need to ask the MG affiliate to install the latest software update. I had the same issue but is now resolved. Once the software update is installed you can once again make a fingerprint of the current map and than download and install your new purchased maps.
They sent a link to a program that loaded the software to a specific level so that the newer update software had the correct foundation to work from.
