MG 4 Long Range miles
I'm getting around 250 from my TLR but sometimes less because I drive with a heavy foot! If I take my time I've actually had close to 280!
Hi all
When I am looking around the expected millage is approx. 280. On 100% charge I am only getting about 220, however when I drive it drops dramatically to around 180 miles, I use Eco mode always.
Anyone know why I would be losing so many miles?
I've found the same thing, but after two years I'm still happy with the car.
Hi all
Two questions:
1. What kind of driving are you doing?
2. What is the miles/kWh value that you see If you go to the Accumulated driving data on the display in front of the wheel?
[If I remember right it's the layered windows button to select the right hand pane so you can scroll through the different time frames.]
Motorway (or fast driving in general) will lower the cars economy (mainly due to drag). Cold weather will do the same (2°C yesterday morning here). Combine the two and things can look a bit rough. Take your time to consider this data MG4 SR EV Database Range and you should get a realistic idea of the varying range in different situations.
Note that 220/50.8=4.33 miles/kWh which would be very good.
Cheers,
Hazardlights
Yeah it was a bit of a shock the first Winter, last year, m/kWh dropping from over 4 to 2 (or less) with the heater on, but it doesn't feel so bad now that I expect it.
I am on 3.2 miles/kWh although I've only had mine for about 500 miles but that includes a couple of drives that have needed a recharge to get home at 20% and a lot of very short school runs.
    Votes: 937 77.6%
    Votes: 178 14.7%
    Votes: 92 7.6%
