MG EHS Brick - Battery problem P1E25 P1B07
Mirek
Poland
Some weeks ago I bought a slightly damaged but non-functioning [brick] 2021 MG EHS . I replaced and completed the necessary components and proceeded to START the car ...
The errors were cleared, and the software was updated with SIPS.
Unfortunately, several errors remained and could not be cleared: P1B07 and P1E25
Following the procedure in the manual [see attached], the car is still a brick, so my brother came with his MG EHS and we swapped the battery fuse from his car -> result no change - brick
To eliminate the fuse, I connected my fuse to his car -> result - Second MG EHS got stuck errors P1B07 and P1E25
I need help/advice if these errors can be removed/how to remove them, by what method/software, or do I need to remove the battery, because maybe the BMS is damaged ....
Any advice welcome
  • P1E25.pdf
    P1E25.pdf
