MG eHS Clock issue
GuizmoFR
Meillonnas - France
Hello,
Recently i discovered an issue with my clock. if i set it on GPS ou DAB, i have an hour delayed. i can't access the options to modify the winter/summer time (set to auto but it's greyed) nether the time zone.
I have to set my clock manually to have the correct hour.
Any ideas ?
Just be careful when setting it on DAB while in France. Ony 2 separate trips my DAB unit and clock froze and I could not change it again. When the unit eventually picked up a Belgian DAB station on the same frequency, I could change the clock. The other time I needed to wait until I landed in Plymouth. Decided from then on to leave the clock as is, and only change from mph to kmh.
Thanks! i think i will leave it as it is (manually). i will check it from time to time to see if the clock is not leaving some minutes from the real time.
