Will this one actually work on our mg hs trophy hybrid was looking at it on there websiteThird Rock energy £214.99
Do not use eBay to buy this item get from a trusted retailer.
I have the same car which I mistakenly assumed came supplied with such a lead. Consequently I had to get one until I had a charge point installed at home. I got a Mode 2 Portable EV Charger | Type 2 | UK 3 Pin Plug but only 7 metre cable from EV-Extras for a little under £140 inc VAT & delivery.Hi I have a mg hs trophy hybrid 24plate looking for a 15m 3 pin charger around £200 any advice
HiI have the same car which I mistakenly assumed came supplied with such a lead. Consequently I had to get one until I had a charge point installed at home. I got a Mode 2 Portable EV Charger | Type 2 | UK 3 Pin Plug but only 7 metre cable from EV-Extras for a little under £140 inc VAT & delivery.
They were very helpful advising on the phone advising, delivery was swift & it worked fine.
Now I've had a HYPERVOLT PRO 3 ,7.4kW EV Charger, Type 2 tethered charger installed, so the three-pin cable is back in its box, gathering dust in the garage...
I have a fast charge cable in the boot for use with non tethered public chargers.Hi
Would recommend you take it out of the box and put in the boot if have a place to store it as you never know when you could need it.
There are some places that will have a out 13amp socket for a granny charging.I have a fast charge cable in the boot for use with non tethered public chargers.
The three pin cable is only likely to be used when staying in holiday lets etc.
