MG ZS EV Radio Module Disconnected
With the radio module being, as you say behind the glove box, how do you access it? Is access from inside the car or from under the bonnet?
Inside, just remove the glovebox.
Undo the big plastic screws on each side on the inside of the box, then pull it down a bit more and pull out.
Had the same thing the other day, tried turning the car off and on again while sitting at traffic lights, when the car came back on I selected drive and nothing happened, couldn't drive, queue of cars behind me, switched car back off, back on, now missed a whole set of traffic light changes with a queue still behind me, car was working again. Still no radio module. Next day got in the car, same thing with the radio module, but this time I sat there for 1 min, radio module then came on. Been fine since but have noticed that the MG badge comes up on the infotainment screen and stays there for a lot longer than usual on start up,
You could try disconnecting one of the terminals on the 12v battery, wait a couple of seconds and re-attach.
A hard reset.
This seems to fix a multitude of sins.
I read this forum and tried reset etc ended up disconnecting terminal took 2 mins and boom all working good, I recon Android auto doesn't help so now I use Bluetooth for Spotify and built in satnav it's just as good, thanks all, I couldn't have sorted it, if I didn't read this forum.
