Mg zs ev
fatih
İstanbul
MG4 SE SR
Hello everyone. How many minutes does it take to charge the mg zs ev long range 180kW charging station from 20% to 100% and from 20% to 80%? How many km can it go on intercity roads at a speed of 100 km/h? I would be glad if you could help... Thank you.
You'll never get 180 kW the max for the ZS LR is about 80kW, also to go from 80 to 100 will take as long as 20 to 80, so it's not worth trying to get to 100. Mine only does 20 kW past 80%. The time form 20 to 80 is about 40 mins.
It really depends on how long you keep that speed and if the road goes up or down and even on wind direction ...
My standard range can go 2-3 hours on motorway and then needs to stop - just when I need to stop for a coffee recharge ...
How many km do you need it to drive in one day?
I live in Türkiye, the distance I have to travel is around 600 km. I travel this route twice a year.
for 600 km, you would need one stop only with long range - that would be 6 hours drive so you would have to stop to rest anyway. 30 min stop is all you need...
even standard range would probably manage with one stop only if you drive slower (60-70km/h) and start with 100%
when I drove long distances with my diesel, we would stop every 2-3 hours anyway ...
Try using A Better Route Planner, enter the details of your car and it should give you a reasonable idea of your expected range on your planned trip. You can refine it later as you learn more about the actual efficiency of your car.
