MG ZS Tyre low pressure warning
I have a new MG4 ZS. I keep getting rear tyres low pressure warning. Is it common?
It's quite common on some MGs @tonytan, tyre pressures go down a bit when it's colder, and this can sometimes take the pressure just under where it should be, but an extra 1 to 1.5 psi in all your tyres will probably cure it.
Upvote 0
Not sure "Cold" applies to Singapore just now ;)
At a fundamental level, you just need to manually check your pressures on a routine basis and adjust as necessary. When ambient temperature rises, you'll find pressure moving in the opposite direction so it can also be necessary to reduce it.
Upvote 0
