Ian Key
Distinguished Member
- Sep 28, 2022
- Location
- Derby UK
- MG4 Trophy LR
Dummy tail pipes to really confuse the boy racers
That's the one that really matters, there's no way I'm sitting around for hours waiting for a breakdown service to come along when I can be back up and running in 15 minutes!Space saver spare wheel and jack kit.
Do you think have a rear camera retro added would invalidate the warranty? Does anyone think it's possible to get a rear camera plummed into the infotainment system so it works and looks as though it came like that without messy cables?Agree!
Such a shame the MG4 have done away with the USB port on the rear view mirror mount. Would have made this a lot less messy. That said, as Miles pointed out, could get it professionally wired in to the fuse box. Definitely be a lot less than the £3K (unless you you really like the spoiler and the extra driving aids).
Quite expensiveHopefully the list of accessories will increase in the coming months.
Official MG4 accessories
I like a spare wheel as well but there is No provisions for a spare on the MG4 and none available from MG and if you manage to find one that would fit it would have to live in the boot I think.That's the one that really matters, there's no way I'm sitting around for hours waiting for a breakdown service to come along when I can be back up and running in 15 minutes!
Be interesting to know the quality of the mats and yes the cables are expensive.The cables are silly expensive, but the mats are cheaper than the £99 the dealer has charged me. Will be sending them a screenshot.
This is something I looked at, I dismissed second hand EV’s inc a 2018 leaf for £18k as it had loads of miles, chademo connection ( which will die out on new rapid chargers in my opinion ) and effectively had no warranty other than the battery.If I recall correctly by the podcast:
1. Type 2 is sold separately (only 3pin supplied)
5. V2l is sold separately something like £150.
I really hope mats are included. Starting to get pricey now (for me) and scanning autotrader I can pick up a 2018 Nissan Leaf Accents for circa £18.
I'm trying to cross reference other cars to benchmark the cost/value relative to like for like cars on the market. £32k is not too far from £36k from a Cupra Born. Which the starts the slippery slope of, well £40k would get me into an Ioniq5...
(Ends up with a mountain of debt and a Porsche Taycan!)
I'd double check the 7yr worry free driving if I were you, I thought that when I got my Kia but turns out that it's not all its cracked up to be & noticed MG one has lots of exclusions too.. For example the air con gas is only covered for 6 months, how crazy is that... The infotainment only gets 3yrs cover along with a list of other stuff..This is something I looked at, I dismissed second hand EV’s inc a 2018 leaf for £18k as it had loads of miles, chademo connection ( which will die out on new rapid chargers in my opinion ) and effectively had no warranty other than the battery.
I got a MG4 SE, £26k, 200miles range, 7 years worry free driving, app to preheat car etc ( until very recently niro’s and kona’s don’t have this )
Aye I had a good read, it’s basically a 3 year warranty on most things, but 7 years on the expensive stuff - motor, inverter, charger, battery.I'd double check the 7yr worry free driving if I were you, I thought that when I got my Kia but turns out that it's not all its cracked up to be & noticed MG one has lots of exclusions too.. For example the air con gas is only covered for 6 months, how crazy is that... The infotainment only gets 3yrs cover along with a list of other stuff..
Was this regarding the reversing camera?Quite expensive
Les
Sorry Jamieev well I was referring to the MG accessories which fiiferMG4 posted,which is why I copied his post and did my answer, but yeh I would think what you asked about the camera would also be expensive if it could be done so sorry for any confusion I may have causedWas this regarding the reversing camera?
Is that because the MG4 has very little rated towing capacity?I have seen no mention of tow bars at the moment
I just want it for a cycle rack rather than towing.Is that because the MG4 has very little rated towing capacity?
Sourcing a correct space saver wheel and jack set won't be a problem at all as soon as the PCD, centre bore, & offset of the wheels are measured, aftermarket space savers are readily available to suit all wheel sizes. You are quite right that It will have to live in a wheel bag in the boot though, which is annoying as the boot isn't huge to start with. There may be scope to turf out the polystyrene insert with the tyre goop kit in it to get a wheel lower though, then refit the floor above it. Might not lose too much space that way. I'll work it out once we get ours as there's just no way I'm driving around with no spare, I can't believe most people are OK with the lack of a spare and the ludicrous inconvenience and use of rescue service resources a simple puncture now causes, how can this be progress?I like a spare wheel as well but there is No provisions for a spare on the MG4 and none available from MG and if you manage to find one that would fit it would have to live in the boot I think.
Les
If the head unit used on the none camera versions is the same, and I think there's a fair chance it will be, there should be an AV input. If so retrofitting a rear camera will be straightforward and doesn't have to be expensive, unless you want to buy the MG part.Do you think have a rear camera retro added would invalidate the warranty? Does anyone think it's possible to get a rear camera plummed into the infotainment system so it works and looks as though it came like that without messy cables?
The vehicle to load adapter is £268, and it's just hilarious, it's literally a £25 double RCD socket usually used for outside wall mounting spliced onto a 16A type 2 lead! It's not worth close to half the asking price.If I recall correctly by the podcast:
Not sure if the price £73.84 includes VAT but even if it doesn’t it sould only be £88.60 when you put vat onThe cables are silly expensive, but the mats are cheaper than the £99 the dealer has charged me. Will be sending them a screenshot.
