MG4 lane keeping assist
For us, front collision assist works so very well, but to note, only when engaging cruise control, non existant when not engaged which we find pointless in congested traffic areas anyway. Makes sense to keep the driver engaged and responsible in whatever the driving environment. That said, I was hoping for full automation but it seems only I can idiotproof myself when I'm behind the wheel...that is when she let's me drive..... Absolutely no issues with our car, the software or the way the safety features work, we have turned nothing off.
Driving the MG4 on heavy snow, where everything in front of the car is totally white, this system still try to intervene. Yesterday like a couple of times a minute. Clearly the system can't see anything, but still think it does and do weird things. Feels like it is best to hold the steering wheel quite tight in case it does anything really crazy. In these conditions this system should shut off, as it is not anything else than dangerous when it is misleading the car left and right all over the road.
Not had a problem with LKA myself. Occasionally it will twitch the steering wheel and/or beep at me but nothing to warrant me switching it off. That's a mixture of country/town/motorway driving. If you're not using your indicator at the correct time then you may get a reminder!
The SR / Standard does not have ELK ... it has basic LKA. (I know the Trophy / Luxury has 2 or more distinct elements to lane keeping that can be configured ... in the SE it is all related to basic LKA: you can set Audible Alert [or not], Vibration Alert [or not], the LKA sensitivity [Low, Moderate, High], and obviously turn the whole LKA On or Off).
As a test I have tried setting LKA sensitivity to High (I normally set it Low) ... on my latest journey (mainly motorway but some smaller roads) I found it be to much less intrusive - my thinking being that perhaps High sensitivity means it'll see road markings more clearly. (I know this seems counter-intuitive). This is an experiment I'll continue with to see how it goes.
I know. That is why I asked Mannakin what he is driving. Current complaints are not and probably never have been linked with the Standard. The versions with ELK cause the complaints (because elk is default).
You misunderstand ... I was finding LKA in my SE to be horrible, so I was always turning it off. So it's not all just Trophy/Luxury owners with specific ELK that are having concerns. (I presume ELK is enabled by default in the SE with no option to specifically turn off only that part of it).
I'm now trying with LKA on but sensitivity set to high as a test.
Have to say I love the car, but I have a very simple pre-flight checklist:
  • If daytime and weather is nice, switch off auto headlights
  • If not snowy/icy/nasty, switch to Sport (otherwise leave in Normal); Sport means the brake pedal responds “properly” rather than mushily
  • Switch down emergency front radar thingy to minimum distance
  • Switch off stupid speed-sign spotter (it spots speed limit signs okay, but is incapable of spotting “national speed limit” signs)
  • Switch off LKA (I’m glad some people like it – driving on rural roads, however, it’s a constant hazard; you never know when it’s going to leap into unexpected action)
Sounds like a long list, but it takes me just seconds to run through. At some point, I’m hoping most of these common settings will make it onto some kind of customisable “Home” screen, but I’m not holding my breath.
Hi,
I am looking to purchase a 2023 MG4 ev in the next month.
Based on looks and value for money they look worthwhile, however I have noticed on videos that the lane keeping assist and front collision assist can be very agressive. Is this still the case or has the software been updated?
Thanks John
The software for lane keep assist has been updated. So much better!
Hello, Is anyone who know if on the 2025 version of MG4 they fixed the LKA issue and others? What they updated or not! Thank you, Bogdan
Whatever car you buy now I suspect strongly would be a 2024 build. That said though, my MG4 is a Jan 24 and LKA is no issue for me, but don’t expect a flawless system because some people do report issues with LKA.
Edit; and welcome to the forum :)
As detailed elsewhere, I switch off (a) LKA, (b) auto headlights and (c) traffic sign recognition every time I get in the car. Takes seconds. I also switch to (d) Sport mode – because of the improved braking, as it happens, not because I fancy myself as the Stig – and set off happily with all worries assuaged (except when LKA very occasionally reactivates itself, which is annoying).
My vehicle is in my profile ;p
It's a 2024 Extended Range - no real idea what it has as i just leave it on all the time \0/
It looks like it wasn't in your profile a year ago.
Anyway, your ER defaults to Emergency Lane Keeping. SE's do not have ELK (at least not in the EU).
Bear in mind that though software updates may have softened the LKA or ELK or whatever it is, not all cars will be updated. Dealerships seem (unless you are lucky) to be taking the stance of "if its not broken we aren't updating it" with all of the software. So a used purchase may or may not have the updated software.
Depending on the software version the LKA can reactivate its self when the infotainment goes from night to day or vice versa. I have never experienced this because I leave my infotainment set to night / dark mode.
Thankfully it can be turned off, although it has to be turned off every time the vehicle goes out of and back into ready mode.
Hello, thank you! In the meantime, I want to drive an MG4 rented "off the street" from My wheels in the Netherlands and see how it really feels.
    Votes: 934 77.6%
