MG4 Luxury 64kWh SOH
BingBong
Eu
MG4 Trophy LR
Hi, i checked my car SOH with CarScanner app. Its reporting 98.2% after 6.2k miles (10,000 km).
As i saw here at this milage most of the cars still have 100% (except in the zs ev forum). My guess is that my car was at storage at 100% in 40°C for several months at the dealer before i bought the car.
Can you please share your SOH and milage? (NMC battery)
Have a look at the podcast from the other evening...
There are some excellent discussions by @tsedge @leomindel @Miles Roberts CG
... in short there isn't a standard method to measure SoH, so whatever you get is an interpretation at that instant in time. Mine is an LFP, but it varies between 95-97% over the past 23 months with car scanner (which ties in with what the energy consumption display gives me on a full to 10% discharge, which was 44kWh on a 51kWh battery (the other day after a long trip)- if my crude maths is correct, I get 95.8% SoH)
there are some excellent discussions by @tsedge @leomindel @Miles Roberts CG
... in short there isn't a standard method to measure SoH, so whatever you get is an interpretation at that instant in time. Mine is an LFP, but it varies between 95-97% over the past 23 months with car scanner (which ties in with what the energy consumption display gives me on a full to 10% discharge, which was 44kw on a 51Kw battery (the other day after a long trip)- if my crude maths is correct, I get 95.8% SoH)
So, if I understood after the app gave you 95% you also got 97% after that on a different day?
Hi, i checked my car SOH with CarScanner app. Its reporting 98.2% after 6.2K miles (10,000 km).
As i saw here at this milage most of the cars still have 100% (but in the zs ev forum). My guess is that my car was at storage at 100% in 40c for several months at the dealer before i bought the car.
Can you tell me yours settings in CarScanner please ? It never work with my MG4, NMC battery...
Go to settings-> Connection profile-> MG -> MG4 (its marked as experimental profile)
It should work with ELM327. If it's work for you please post your SOH ?
It's already set
But I don't have the last update on my OBD Adapter so I'll try that.
Thanks
I try again yesterday. Doesn't work. So I bought pro version, I'll try later and let you know
So, What I get now.
SOC in car 83%, SoC Display 78,6% and SOC 77,1%
I'm so confused...
Car Scanner said my SOH is 99%, dealer 97,5% during the first service 1 month ago...
So, What I get now.
I'm so confused...
The soc difference is also at mine. I don't know why. But looks like the SOH in the scanner is correct.
I verified it by resetting the trip data. After you reset the main trip data the GOM (estimated kilometers) should go back to WLTP data minus the degradation %. (At normal mode, with no A/C.
That's mean that if the WLTP range is 435KM, at the GOM at full charge you should get 430-431km (or 356km at 83%). (You can check on the charging limit scroll after reset) i am getting 426KM which is 435 - 2%, but half the mileage of yours.
Thanks @BingBong
I'll perform some check every other day to have a sample to compare.
I'm my MG4, the charging limit scroll is bigger than the real range, every time.
I'll try to charge at 100% and reset the main trip to tell you what I have but so far, I don't have the feeling that I have less range that I when I got the car one year ago.
    Votes: 908 77.7%
    Votes: 171 14.6%
    Votes: 90 7.7%
