Somebody on Faceache has posted this reply at 16:49 today (28/10/2022) from his dealer when asking about the oil leak. I have removed the names.
The part ( it is neither the cause nor the solution to the problem ) gets me so what is the solution.Somebody on Faceache has posted this reply at 16:49 today (28/10/2022) from his dealer when asking about the oil leak. I have removed the names.
I think they are implying that the breather pipe is not the cause of the oil leak so replacing it won't be the cure.The part ( it is neither the cause nor the solution to the problem ) gets me so what is the solution.
nope didn't work on mine still leaked. Waiting for new breather.I think they are implying that the breather pipe is not the cause of the oil leak so replacing it won't be the cure.
It looks like MG are sticking with the overfilling the transfer box is the problem so taking some out is the solution.
Yes, I think it is poorly worded. The MG bulletin I have says that the breather is a fix for the problem, otherwise why bother? But some cars had the wrong level of oil too.I think they are implying that the breather pipe is not the cause of the oil leak so replacing it won't be the cure.
Can’t agree with you there Alb, it didn’t, there are several owners here who have had the oil removed and the gearbox refilled to a lower level and have still got a leak after.whereas a combination of the original breather plus a less than normal oil level resulted in no leakage
I said it was what I could visualise as a rational explanation, not what actually happened. Besides, we have no knowledge of how accurately a 0.7 litre fill might have been determined so the margin between problem/no problem might be incredibly fine. All conjecture of courseCan’t agree with you there Alb, it didn’t, there are several owners here who have had the oil removed and the gearbox refilled to a lower level and have still got a leak after.
Ah it’s a placebo breather. Words fail me!Somebody on Faceache has posted this reply at 16:49 today (28/10/2022) from his dealer when asking about the oil leak. I have removed the names.
Interesting speculation.I have a theory. The oil, regardless of the amount ,it seems is coming out of the breather. That suggests to me that the breather is in the wrong place , it is in thr direct line of where the oil is thrown , hence it leaks out. A breather should be in a place away from where the oil is thrown by the gears so that it allows gasses to flow but never gets directly subject to the oil being thrown around the cavity. So I think the long term solution would be a re designed gear casing with the vent in a better position. Just a thought !
Agreed. The difference between 0.9ml and 0.7ml is about 3 egg cups which could easily be left smeared around the transfer box and gears.I said it was what I could visualise as a rational explanation, not what actually happened. Besides, we have no knowledge of how accurately a 0.7 litre fill might have been determined so the margin between problem/no problem might be incredibly fine. All conjecture of course![]()
Major job but you might well be correctI have a theory. The oil, regardless of the amount ,it seems is coming out of the breather. That suggests to me that the breather is in the wrong place , it is in thr direct line of where the oil is thrown , hence it leaks out. A breather should be in a place away from where the oil is thrown by the gears so that it allows gasses to flow but never gets directly subject to the oil being thrown around the cavity. So I think the long term solution would be a re designed gear casing with the vent in a better position. Just a thought !
Absolutely!Ah it’s a placebo breather. Words fail me!
Yes, another reason to avoid ICE cars if you want automatic transmission (all flavours of which have their own disadvantages - reliability being one of those of the dual-clutch offerings).If you thought the MG4 had a transmission problem spare a thought for Kia and Hyundai owners. They have issued a recall for 112,000 cars because the cars loose all power with a 20 to 30 second warning because of a manufacturing fault with the dual clutch gearbox.
I can only speak from experience but I have had 2 Ioniq hybrids with 100% reliability. Only reason I ordered MG 4 is because Hyundai do not do an affordable EV that I like.If you thought the MG4 had a transmission problem spare a thought for Kia and Hyundai owners. They have issued a recall for 112,000 cars because the cars loose all power with a 20 to 30 second warning because of a manufacturing fault with the dual clutch gearbox.
Indeed. The complexity of today's ICE transmissions is horrendous, all simply because a fossil motor has such a narrow power and torque band, electric motors are so cool in comparison- one ratio ? no probs, I can work with that ( says a motor )Yes, another reason to avoid ICE cars if you want automatic transmission (all flavours of which have their own disadvantages - reliability being one of those of the dual-clutch offerings).
In fairness it is only the dual clutch gearboxes that have failed in SOME Ford Focus, Hyundai, VW's and a few other related brands and in many cases it was because owners had no idea how to drive them without burning out clutches. I had a Renault Clio RS 200 (hot hatch) for many years with a dual clutch auto and had no issues with it because you need to drive them like a manual car with an auto option and not allow them to 'creep' in traffic or not allow the transmission to hold the car stopped on a hill but use the brakes in the same way you would preserve the clutch on a manual car.Yes, another reason to avoid ICE cars if you want automatic transmission (all flavours of which have their own disadvantages - reliability being one of those of the dual-clutch offerings).
