dragon2611
That’s interesting and a little concerning as I believe everyone else who was having this issue had a late model pre facelift which presumably has different software.
Good morningn,That’s interesting and a little concerning as I believe everyone else who was having this issue had a late model pre facelift which presumably has different software.
We will see its a bit disappointing so far this will be second viste to the garage for the first 10 weeks, last time two of the doors stop opening from inside.Yep worth getting it checked, I wonder if they'll actually do any diagnostics on the HV battery or just look at any stored fault codes and clear them.
Since the balance charge 12v battery is showing solid 12,7v and not dropping.It sounds like your 12v battery may be part of the problem. 11.3v is very low considering the battery doesn't really get used for much. I think failed rapid charges can cause 12v battery problems. It might be worth checking the voltage a few times to see if it is regularly below 12.1v as without leaving the lights on etc. It shouldn't really fall that low.
Ahh that's good. Just thought it was worth checking that it hadn't been damaged but as far as you can tell without testing it that looks fine. If you have trouble with the 12v allot of places that sell replacementa such as halfords will check the health of the 12v battery for free without obligation to buy anything.Since the balance charge 12v battery is showing solid 12,7v and not dropping.
However I will book service for diagnostic.
Thank you for the advice.Ahh that's good. Just thought it was worth checking that it hadn't been damaged but as far as you can tell without testing it that looks fine. If you have trouble with the 12v allot of places that sell replacementa such as halfords will check the health of the 12v battery for free without obligation to buy anything.
Mg customer services will just refer you back to your dealer as MG technical are not customer facing.Hello, how fast did you received a reply from customer.service@mg.co.uk? I emailed them monday and nothing yet, not even an acknowledgement of my request or that it will be passed to or dealt by some department.
