No welcome or interior lights, and no pedal function to open the boot
jorge9r
Madrid
Hi guys
I'm new in the forum, I got my Marvel R Performance just yesterday but I'm struggling with the lights.
Apparently all the settings are on for "follow me" lights and the lights inside when opening the doors or unlocking the car but they go on when I unlock the car or even open a door.
Also in the boot, there is no light on when I open it...
Additionally the function to open the boot with your foot underneath the car back is not working and it's on in the settings.
Is there anyone else experiencing something like this? Specially with the lights, it's really annoying because as soon as I turn the car off it's completely dark without daylight.
Thanks
Upvote 0
Go to SYSTEM then you have the Version and the update detect option. The rest (RESTORE TO FACTORY SETTINGS
Hi guys
Thanks
Hi,
-Check the 12V battery condition.
-Check the remote controller key battery.
-Try to reset the system factory.
Go to SYSTEM then you have the Version and the update detect option. The last option is RESTORE TO FACTORY SETTINGS.
Do not forget to detect for the last or newer version after reset and Login.
Reset may take 30 minute or longer.
My Marvel has not had any of your Marvel issues.
But try the above, may solve the problems.
Upvote 0
Hi,
Hi Mila
Thanks for the hint, I tried to reset to factory settings but it didn't work. As for the interior lights, they don't switch on when opening the doors but they go on when k switch them manually...weird.
I'll make an appointment with at the dealer workshop, I believe there is something wrong.
Upvote 0
Hi Mila
Check also the switch of the interior lights if it is off.
Regards
Upvote 0
Did you try kicking your foot back and forth few times like it says in the owners manual? You can look underneath to see the position of the sensor wire it is T - shaped, try kicking close to wire.
And It doesn't work with power on. Car can be locked or unlocked but has to be turned off for the boot pedal option to work.
Upvote 0
