rigby44
Does anyone reguarly use the pre heat button on the app? Tried it this morning now winter seems to have arrived, refused to function and didnt activate.
Does anyone use it reliably?
It was Rolfe. Does it not like that?Was your car plugged in but not charging at the time?
Thanks Rolfe.This is a known bug. There are some owners who report having had a software update that fixed it but it's an irregular thing and I don't think we know which update. When I asked my dealer about it they said they couldn't investigate it because the car was paired to my phone and I hadn't left the phone with them!
I am expecting a flood of people complaining about it as the cold weather sets in, and hopefully enough people will do this to get MG listening. If there is indeed a software fix it shouldn't be all that difficult to figure it out and apply it. So get complaining.
In the meantime, the workround is to go out into the snow and unplug your car, then come back in the house and get warm while the car pre-heats. I know, it's mental.
Thanks Rolfe.
The whole software situation is the gift that keeps on giving.
We charge every other night as the octopus Go window is short, and the missus does 50 miles a day. That means 50% of the time she wont be able to pre-heat the car without first going out and unplugging.
Theyve alot of ironing out to do.
Yes, always when charging complete. Odd that it works for me and not others. Haven’t had any updates done on the car since getting it earlier in the year.I don't think it's anything to do with the infotainment sysem. (I'm also on R13 and I have the issue.) I presume your car has finished charging when you get the heating to work? In that case you don't have the bug. I believe it will pre-heat if the car is still charging though.
Someone dreamed up a complicated work-round involving setting the timer on the charge so that the car doesn't charge to 100%, then starting the charge again from the app before sending the pre-heat command. I think it might just be easier to go out and unplug it!
I swear I saw someone quote an update number that fixed this but I can't remember where, now.
If plugged in but not charging presumably rather than go out in the cold you could just turn on charge for 10 mins (assuming not charged to 100%) as an extra 10 mins at non night rate wouldn’t be much cost?The pre-heating seems to work pretty well otherwise. I used it last night before going to pick a friend up for choir practice, then again just as the conductor seemed to be getting ready to wind up so that the car was cosy for us to return home in.
