R63 upgrade software - maybe
ECourts
Munich, Germany
MG4 XPOWER
My XPower was upgraded to R63 yesterday. The dealer left a USB stick in the car, which seems to have MG software on it, so may be the stick that was used to do the upgrade.
If the contents may be of any use to anyone let me know. I've no idea how, or even if it can be used.
Check on your Charging tab under the battery tile ... can you adjust the charge limit? (Default is 80%). If not then they haven't properly completed the update.
There is a slider against a silhouette graphic of the car. The (my) slider can be moved left to right to reflect charging maximum and resulting range. Is this what you meant?
