Hi
@Mihir - thanks for posting your findings.
1.Range - You do not state what driving mode you where using at the time ?.
I am going to guess and say NORMAL ( default mode ) and therefore re-gen level 3 also ?.
If in ECO mode, the re-gen is weaker if I remember correctly.
Your consumption of the range, is affected by many different factors as you already know.
The predicted range before starting the trip was 211 miles I think you stated.
 Question :- Did you reset BOTH trips prior to starting your long trip, as this figure feels a little optimistic to me ?.
You may well have seen a different prediction in range had you reset BOTH trips first.
If I have a longer trip to make ( like on Monday ) and intend to fully charge the pack the night before, then I ALWAYS reset the trips prior to charging to full.
The "Accumulative" trip stores your historic data, so if you have been conducting some lower speed town driving etc over the previous days and your efficiency is GOOD - It assumes that your following trip will be the same.
Therefore the reported prediction of your range, is based on the historical data stored, unless you reset the values.
We all want to believe that mileage we are seeing ( 211 ) is actually achievable in distance, but that is rarely that case.
So, you fully charge and your historical prediction is 211 miles, but this next trip is now all motorway driving, you may get a shock to see your range tumbling more quickly than you expected.
The car is now quickly trying to recalculate it's previous prediction of your remaining range, while now on the move.
This is why I believe your mileage dropped faster on the out going part of the longer trip, as it was re-evaluating it's first prediction.
It had a better handle on the situation on he return leg !.
Resetting the trips prior to making a longer should help avoid this situation.
I would say after two yeas of ownership, that the GOM does a fairly good job of predicting the range when the trips reset.
Not sure if the new face lift model SR is set up in the same way as the previous Gen1 version on the latest BMS software, but I would think so ?.
2. KERS - On the Gen1 ZS EV with the latest BMS update, the re-gen becomes available much earlier than the original BMS software, but again this is dependant on different factors, like ambient temperature / drive mode selected etc.
Re-gen is much weaker when the ambient temperature is low.
3. Silly moment - Yes closing the car down at a set of traffic lights, is not a great idea to be honest.
Had you rushed the "Boot Up" it could been a "Not Recommended" moment
Never mind - it happens !.
