Rear knocking sound when reversing?
GameZone
Norway
MG4 Trophy LR
I sometimes here a slight knocking sound from the rear when reversing, especially if it's a slight hill. Anyone else have experienced this?
Try extending the rubber buffers at the bottom corners of the hatch a little or put a bit of insulation tape around the catch.
If none of the above works I'd consider having the end links/drop links looked at as the noise & conditions described are identical and an extremely common symptom of them being slightly loose. As they're connected to the rear sway/roll bar and sub frame the noise comes right through the cabin
    Votes: 936 77.6%
    Votes: 178 14.8%
    Votes: 92 7.6%
