So, it is fixed and since I quite like to see photos before I tackle something I shall present some here.
1. Disconnect the battery…you are going to be working near an airbag so it’s a good idea.
2. Remove the door seal around the front half of the door.
3. Remove the fuse box cover panel to check for any water hanging around. This is probably optional.
4. Remove the A-pillar trim panel; the top clip just pulls apart but the part on the panel needs sliding up to remove it from the panel as it is tethered to the other half. There is one more standard clip about halfway down. Take care of the speaker wire which can be carefully disconnected.
5. Behold the idiotic place that a joiner has been placed. Rejoin and secure the hoses with cable ties, nice and tight to hopefully prevent it from coming adrift. Make sure to fasten the ties inside the barb.
6. Assuming all is well (perhaps test first) you can refit the pillar trim (don’t forget to plug the speaker back in!) and the fuse box cover. Refit the door seal, ensuring that you push it nice and tight into the corners otherwise you’ll end up with some left over.
7. Rejoice in having done a good job and have a tea or coffee, bearing in mind that you definitely deserve a chocolate digestive or two.
Huzzah
