Recently fitted
  • Thread starter Thread starter Deleted member 11291
  • Start date Start date
  • Tags Tags
    mg4
While charging this morning decided to fit recently purchased mud flaps, mats and centre console box. Rear flaps a bit awkward but managed to fit without removing wheels.
Sorry, should have mentioned will be making my own undertray if required…….
Look in MG4 Mats Availability​
post 300
Ah I see you’ve got the wooden undertray and camouflage paint option, very nice!
Since you replied, I have been wracking my brain. Im sorry but I don't see what you mean……..
The mud flaps and mats are laid out on a piece of wood which resembles a car undertray/floor, and the charging cable is laid on it as if it was plugged in, and so it was a bad joke about the rest of the car being invisible (camouflage paint).
if it requires explaining accept the fact your wit and sense of humour is above average
on a different note , who fitted your wall charger? is it a 7 kilowatt one? and what is the rating of the junction box? 32 amp ? im assuming it was used to replace a previous garage fuse board
Love to know how you made pilot holes for rear mud flaps without removing wheels.
I am wrestling with this issue at the moment
Remove the bolts, and use them to fix mud flap, do not tighten until all started, bit fiddly but possible, or remove wheel ?
Hi I have a set of flaps from Ali express front ones line up fine we’re easy fit
but the rear ones holes don’t line up I think they’re the wrong ones did you get yours from them
I had mine from Ali Express.
The front and rear location holes appear fine, so perhaps you have been sent the wrong rear set.
Hmmm, I did think the same about the wall box….
It looks a bit like the incoming supply cable comes in from the CU in the garage and feeds into that single “Wisker” box that is likely to have Waggo connectors inside.
Maybe the charger has been replaced ?.
    Votes: 911 77.7%
    Votes: 171 14.6%
    Votes: 90 7.7%
