Reverse camera 170 degree with dynamic parking lines and mirror monitor with 7.5” 1080p display
rayzfun
haverhill
MG4 SE SR
Hi all just thought I’d share the reverse camera installation in my MG4 SE LR. I’ve installed a 170 degree camera with dynamic trajectory parking guidance with a 7.5” replacement rear view mirror 1080p. Not the easiest installation but I think it’s very effective and looks very OEM. Camera is situated in the same place as trophy rear and video cable runs through the rear hatch into the chassis via the rubber cable channels and via the footwells to the A pillar and headlining to rear view mirror. Camera power is via the reverse wire positive and negative in the left rear light cluster using good quality wire taps. Easy to get to through the removable access panel in rear hatch. Also easy to remove light cluster via 2 x 9mm bolts. The rear view mirror has its own bracket that is compatible with the mg4 windscreen. I’ve attached pics and happy to share links to my purchases if you’d like.
Looks great. The camera is nice and discrete and very OEM looking. Which model is it, and did you have to do any drilling to install it?
Just a couple of discrete holes, on the underside of the boot handle and inside the tailgate so the video cable can be thread through the tailgate and into the car body. If you look at the pics you’ll see one black wire next to a black and red wire, this is the hole inside the tailgate
Really clean job you’ve made of that
Just found this amazing item on AliExpress. Check it out! £52.81 4% Off | ANSHILONG AHD 7.5" TFT LCD Rear View Mirror Car Monitor Video Input 2Ch with a Special Mounting Bracket
52.81£ 4% OFF|ANSHILONG AHD 7.5" TFT LCD Rear View Mirror Car Monitor Video Input 2Ch with a Special Mounting Bracket| | - AliExpress
You need bracket #225
Just found this amazing item on AliExpress. Check it out! £22.36 40% Off | Greenyi CVBS 720P Golden Fisheye Auto Parking Intelligent Dynamic Trajectory Parking Line Car Reverse Backup Camera
Is that the one you fitted at the start of this thread?
