N2STY
Distinguished Member
We are in danger of going round in circles here ?I think this the 'dead reckoning' problem
Anyone hear the Magic Roundabout music playing in their head?We are in danger of going round in circles here ?
It's time for bed said ZebedeeAnyone hear the Magic Roundabout music playing in their head?![]()
Brilliant. I've just done what you suggested so will test tomorrow. It's been a bit frustrating these last 4 days since collecting. Most appreciated!I had same issue. Dealership hadn't a clue. However after much perseverance I found the issue. Go to sat nav, then settings, then map features. Turn off "dead reckoning". Then reset info system by pushing down and holding the physical home button not the one on the screen. Hold it till the MG emblem comes back on then release. Hey presto the sat nav will now work.
Try Mel's suggestion first.Took my new ZSEV back to dealer to fix Satnav. Assured me it was working. wrong! I bet they never took it on a test run. Looks to work perfectly when stationary. Solution, book it in again!
No worries that's what the community is for.Brilliant. I've just done what you suggested so will test tomorrow. It's been a bit frustrating these last 4 days since collecting. Most appreciated!
I’ve had the same problem. Got rid of the dead reckoning and pushed the Home button. Sat Nav working ok now.No worries that's what the community is for.
Its a shame the dealers arent as pro active. Just need to figure out how to stop the radio from pausing and changing source everytime the phone gets a message now......
Have you check if you have an update available in settings. Factory reset is the other option but you loose all of your stored settingsHas anyone a MG ZA EV 2022 version. I can’t get the satnav to move when I move. It’s stationary all the time?
For anyone (hint-me) who is loathe to RTFM, how does one navigate to where you can check for updates?Have you check if you have an update available in settings. Factory reset is the other option but you loose all of your stored settings
I had the same issue. It worked for me. Thanks ? ?I had same issue. Dealership hadn't a clue. However after much perseverance I found the issue. Go to sat nav, then settings, then map features. Turn off "dead reckoning". Then reset info system by pushing down and holding the physical home button not the one on the screen. Hold it till the MG emblem comes back on then release. Hey presto the sat nav will now work.
Go into sat nav settings and turn off dead reckoning.Has anyone a MG ZA EV 2022 version. I can’t get the satnav to move when I move. It’s stationary all the time?
Turn off dead reckoningHas anyone a MG ZA EV 2022 version. I can’t get the satnav to move when I move. It’s stationary all the time?
