Hi guys.
Has anyone had issues with the scheduled charging on the MG app.
We borrowed a Tesla granny charger from a friend and set the app to charge 12-7 overnight - cheap ev rate.
To our frustration we woke up at 9am and the car was still taking charge. This means it’s been charging for 2 hours at 45p/kwh ?
Any ideas folks?
There is no consensus about the scheduling problems on the MG4, but there are three approaches, each with their own advocates (see at least three other threads):
1. Use the in-car scheduler, with the iSmart app turned off.
2. Use the app for scheduling.
3. Use your home charger for scheduling - PodPoint, Ohme etc - and forget the car option.
I use option 1, and it works fine for me. The important thing is to have the app turned off from before you schedule charging on the car, to after you finish charging. My theory is that if you schedule using the car, then when you use the app for anything, the car interprets this as the app overriding the car's schedule. The car may then set itself to start at 10pm (default) for example, ignoring the original schedule.
I have a PodPoint, and can confirm that Option 3 works with that charger.
If you are using a granny charger, you can't use option 3, so give option 1 a try. Resist any temptation to start up the app!
