Pebblefeline
Highly technical solution while waiting for my ohme install.
works perfectly
There is no issue using an AC timer to start the process but it’s not advisable to cut the power while charging is still ongoing.Highly technical solution while waiting for my ohme install.works perfectly
20 quid from screw fix
In terms of stopping charging whats the danger of killing the power?
I may need to change my habits………..
That depends on the ‘granny’ and your DIY skill. It is possible (I have done it myself) to interrupt the low voltage control lines to allow scheduled charging based on the idea below.Not much choice if you want to make use of cheap rate electricity over night and only need to use a granny charger.
What is even stranger is that the instructions for most granny chargers is switch off the AC power first and then unplug the type2 plug. Using a time switch is just another way of following these instructions.Been doing it this way for years, admittedly with an electronic 16A timer. Not much choice if you want to make use of cheap rate electricity over night and only need to use a granny charger.
Simple reason, you can’t unplug a type2 on the car side while charging is ongoingWhat is even stranger is that the instructions for most granny chargers is switch off the AC power first and then unplug the type2 plug.
Correct, but IMHO the manual should mention to stop an active charging session before removing any cablesUsing a time switch is just another way of following these instructions.
I am confused as does this mean that you can stop a charging session from the car?Correct, but IMHO the manual should mention to stop an active charging session before removing any cables
Every wallbox on the market has mechanical relays in there to switch current to the EV, they can (and do) open under load creating the exact same conditions that you say damage the cars electronics (mechanical contact opening under load). Yet, you don't hear of wallboxes wrecking car electronics?Generally speaking if you mechanically interrupt electrical current you create an arc that is bad for the contacts.
The on board charger on an EV (or CCU in MG terminology) is designed to safely dissipate energy before the contacts are opened, simply cutting the power may create energy surges that can damage (expensive) electronics.
Some owners out there will say that they have been using mechanical timers for years without apparent issues but IMHO using a 20 quid timer to charge a 20 grand EV is false economy.
The negative effects of disconnecting under load are rarely instant therefore you won’t ‘hear of wallboxes wrecking car electronics’.Every wallbox on the market has mechanical relays in there to switch current to the EV, they can (and do) open under load creating the exact same conditions that you say damage the cars electronics (mechanical contact opening under load). Yet, you don't hear of wallboxes wrecking car electronics?
I accept that most of the time a gracious stop to the charging will take place i.e. charge rate reduced by pilot signal but that isn't always the case.
There will be good input protection too on the onboard charger.The negative effects of disconnecting under load are rarely instant therefore you won’t ‘hear of wallboxes wrecking car electronics’.
The component themselves do usually have a good tolerance for abuse if decent quality. The whole unit will be well protected on the input side. I seriously doubt using a timer operated micro switch is going to cause any issues.Of course nowadays components are designed to withstand a number of power surges (that’s why I used the word ‘may’) and the likes but everything has a limit, ‘death of thousands cuts’ comes to mind.
I can go with that, you’re wrong ???I’m We have to agree to disagree
Absolutely 100% BUT, the timer should be ok too.but IMHO the safest way to schedule a charge on a PFL MG5 is using a wall box that is capable of doing so.
Try the unlock button on the keyfob that usually releases the cable for me unless the cars throwing a hissy fitI've clearly been doing it "wrong" as well. IME the only ways to unlock the cable from the car is to either charge to 100% or unplug the charger.
