Setting the clock
Jayenn
Nottingham
MG4 Trophy LR
My MG4 is too smart/complicated for me. Can someone please help with where to access settings so I can change the time? I had hoped I could leave setting the clock to the car and it would adjust to GMT from BST automatically. Thanks
Swipe left to get to the next page and then settings You should see below from @Ian Key (view the attachment):
It's because I specified London
If I turn on Use GPS time it adds an hour
Note, depending on your version you may/may not see an option for DST. If you set to use GPS the time changes should be automatic.
It will do that if you find the right setting. I'll have a look.
Welcome to the forum, by the way.
Thank you, on both counts.
Thank you. Sorted.
Just back from the dealer after the 2 year service and upgrade to R63 infotainment. Although the time is actually 17.18 the clock is showing 22.47. Use GPS time is set. The only option I can see is to go manual, which works but I would prefer it to be automatic. Any ideas what's happened or how to resolve? Thanks
Resolved - car was set to London time zone - I went in to change and selected London (Again) - time then showed correctly without going into manual mode
I'm pretty sure that the MG4 is sensible, in that as soon as my UK one went to france it changed the time, but also mph went to kph?
    Votes: 933 77.6%
