So as an update. I tried:
1. With the car locked and plugged in. Initiate a 3.8 Kw/h export (solar & battery). - The car held a steady charge
2. Car as above. Removed the battery from the export so purely solar at 2 Kw/h - The car aborted the charge
3. Unplugged, unlocked the car, plugged in. - The car starts a charge, locks itself, then aborts
4. Unplugged, locked the car, plugged in - The car starts a charge, then aborts
5. Car locked and plugged in, reboot the Hypervolt - The car starts and holds a charge
6. If I interrogate the car whilst charging via the app, it will sometimes abort the charge. But this random
7. Called 'Hypervolt' to find my charger had an old firmware version. They have now updated it. Why I had to call to obtain that only Hypervolt knows !
As a note, every time the car initiates a handshake with the charger and begins to charge or abort, the screen displays the information, locked or unlocked.
So now I'm testing again with a new firmware on my charger !..... Who said owning an EV would make life simpler ??
An unexpected test.....went out to the car with 2.8 K/Wh being generated by the panels only to find the car had stopped charging
. Panic ensued and was close to pulling my hair out... until.... I found my wife doing some ironing.... Lord knows... patience is a virtue with a tech home and vehicle !!
