Solar with battery, loving it!
If you study this for a few days you quickly realise:
  • We are still heavily dependent on gas, that's the biggest source of electricity in winter by far (typically 40%).
  • We are still using coal (1 power station left, due to close in September).
  • Around 10% of our power is now imported from connectors to Norway, Denmark, Belgium, France, Netherlands. We also supply Ireland and sometimes export.
  • Nuclear is a really small fraction.
  • I didn't realise we were burning so much biomass, wonder what this is specifically?
  • Solar is disappointing in winter.
  • Wind, when it blows, is great but it doesn't always blow.
  • There's clearly money to be made speculating on the wild price swings throughout each day.
  • We pay an awful lot more than the cost of generation: there's a ton of costs on top.
I do look at this often and you have noted a few things. The coal has been used quite a bit recently but only when everything else is maxed out.
Nuclear when at full whack is delivering over 5GW which at normal (not freezing cold) total demand can account for about 16% of demand. Hopefully the new nuclear stations can be completed and commissioned as soon as safely possible. These will add a lot.
This leads to a conclusion that battery storage is greatly needed and the grid needs to pull their bl**ding fingers out and get these connections made. There are loads of constructions crying out to be connected. This would easily remove the coal and possibly the biomass and go some way to supplementing the power when the wind ain't blowing.
Would u not pump excess power in to a vehicle as I do 5 hours a day for vehicle, my system at the moment in summer can do over 40 kWh a day .
I dont, pretty much all generated power less the house usage I aim to export into the grid. I also aim to consume the energy from the batteries through the day. At night I then recharge all batteries and run numerous other devices and appliances. Why? - I can export at 15p and buy it back at 7.5p.
So I got 19 panels and two 5kWh batteries installed for £12.5k and absolutely loving it. 9 panels facing south and 10 facing mostly east and a little south. Generating plenty to power the house and the two cars and exporting some on a bright day. Wish I had done it sooner.
That seems like excellent value. Octopus have just quoted me £11200 for 12 panels and one battery!
Unfortunately our roof is split NW and SW.
my neighbour (same roof) had panels fitted to both elevations but octopus have only quoted for one side at the moment.
Going to speak to them next week about a more detailed quote so will see what they say.
Andy
Andy
Hi my system 6.6 kW today it generated 40.5 kWh and it was installed for AU$4500 no battery, [ yours ] seems expensive by Australian prices, and German inverter.
Yeah, I think you might be right. To be fair it’s probably just a generic quote but it is looking on the expensive side now.
New here, hi all
Last month (Jan 2024) we went for an expensive solar setup, it was not the cheapest, in fact it was the most expensive but the person who came to price up was absolutely great unlike all the other companies who came round.
FYI, talk to someone who has had solar installed first to get their opinions and then read up about it all, then get several companies round to quote.
I am quite technical, electronics and mechanical and also a software programmer for approx 30 years, so I had an idea in my head what I wanted.
I wanted the best system that I could on the roofspace I had with enough battery storage to last a day. My electric usage is approx 22kWh a day (lots of IT stuff at home :-) ) so when the Ukraine war started and the prices shot up is when I decided to make the move to Solar etc.
I also wanted a EV charge point installed as it would be cheaper doing it all at the same time instead of 2 separate jobs and one day we might need it or if a friend/family come round they could also charge their cars if needed, a bit of future proofing. My 10 year old 4x4 Yeti was getting a bit old and my left leg is not great these days so was thinking of getting an Automatic or something with a DSG gearbox.
So I go no idea who local Solar companies are around here, I looked on Google etc but could only find 1 local company and they were 20 miles away. I came across the Renewable Energy Association site and they do the leg work for you and got 5 other companies to contact me.
So, I arrange the local firm and the 5 others to turn up and to quote and this is when I noticed something iffy
4 of the companies where not interested in what I wanted and insisted I go with their recommendation and all quoted around £6000 to £7000. 1 of them even argued with me that I knew nothing and they knew what I needed, needless to say all of them disagreed that I needed batteries and I only needed a small 4kW roof system. 3 other then also said I did not need a charge point for an EV as it would not work on my electric system!
The last 2 companies where both on par, their recommendations were exactly what I had wanted so I knew I could trust them better and 1 quoted £15,745 and the other was £16,200.
I went with the £16,200 quote as the person who came was absoutley great and down to earth, he was the boss and not just a sales person. I explained to him about the 4 iffy companies and he said quite a few dodgy solar companies just buy cheap solar net and just flog that regardless of if it fits the requirements as it's just to get your cash.
Anyway, a few months later is installation time (end of Jan 2024) and went with 14 high spec Eurena Panels each at 483w making a solar array of 6.7Kw, this is hooked into a Luxpower Hybrid Inverter (A real heavy beast), a combiner box for 2 batteries, these being Hanchu ESS 9.4Kw each making a storage of 18.8Kw. There is room for another Hanchu battery when they said I can order in 6 months time if I needed the extra capacity and order at cost instead of retail. Also there is NO VAT on anything!!!!!!
The EV point they put in was the 2.1 Zappi which is a 7Kw.
My roof is absolutely covered in the 14 panels and it all faces due south, perfect.
I moved away from Scottish Power to Octopus and went onto their FLUX tarrif which gives cheap rate electricity between 2-5am
Been running for approx a month now and it has rained nearly every day so the 18kW batteries are being charged within the 2-5am period and the house runs virtually on batteries all day and most of the night when it needs to dip onto the grid, this is when I might get the extra 9.4kW battery installed in a few months time but come April I don't expect to use hardly any grid power at all as the system could be making 60kW a day fro solar, so plenty to charge the Hanchu's and export back to the grid (especially during the 4-7pm slot they the export rate is very good.
The other day we decided to look at getting an electric car of some kind instead of a petrol/diesel car especially as we had the zappi now and my left leg which has permanent sciatica due to nerve damage in my spine is casing me to constantly stall the car.
Looked around several of the main dealers as things were nice espeically the VAG ID range.
Anyway, the other Friday we decided to pop into Redditch to sit in an MG and see how comfortable it was. It was comfortable and we were suprissed to know the salesperson from several years ago. Anyway we got an brand new MG4 and I pick it up tomorrow (Yes I know the 24 plate come out soon but it does not make a difference to us as we intend to either give it back and get another at the end of the 3 year 0% PCP or pay the last payment of £15,000 and keep it for many years.
Back to solar, the Luxpower has a weather system built in and it decides how much to charge the Home batteries depending on the amount of predicted sunshine the next day, and this is working great as it it's going to be really sun then the batteris don't need grid power between 2-5am as their will be plent of solar during the day.
With the Zappi you can tell it to only use solar power to charge or mix it with grid, so as I currenly don't work much I am at home most of the day, so will just leave the solar to charge the MG4 Trophy during the day.
FYI: If you have the Zappi, it does have an issue with connectiong to WiFi 6 speced routers, so I have just placed a defunct BT homehub into the garage and it just acts as a WiFi Access Point, to connect to my home LAN I use Devolo 1Ghz Powerline which still works great over the main 16mm arouned cable from teh inverter to electic meter, the solar installers took out the old single (16a) cable run to the garage and and connected the garage directly to the inverter 80A connection, so plenty of power now in the garage.
Any questions just ask. Also the Solar Installer was Craig Michaels Renewables in Telford. We trusted him!!
New here, hi all
I wanted the best system that I could on the roofspace I had with enough battery storage to last a day. My electric usage is approx 22kWh a day (lots of IT stuff at home :) ) so when the Ukraine war started and the prices shot up is when I decided to make the move to Solar etc.
Love what you have done, just sooo expensive in uk for solar do u get any gov rebate for going green?
Hi Adam, that sounds like a very good deal. Who was your installer?
SWS in Widnes. Unfortunately they now have a 3 year waiting list and are doing commercial only now. So I think I just about got in there.
We've got solar, 2x9.7kWh batteries plus 2x EVs. 1 EV is capable of bi-directional charging too (but our charger isn't ? ).
The quickest way to get your ROI is to charge up overnight at low rates and export (at twice the price) to the grid when generating excess solar.
Octopus do some great tariffs.
Hi Fred I like you have not got home batteries but I do have solar and I understand about the V2L scenario and where your coming from, I have have experimented with it a few times with both my MGs that being the 4 SeSr and the 5 face lifted trophy,
Yes you can do many things with this but it has its limitations I purchased the official MG V2L adapter from my dealer and have been using it with some gardening equipment at a cemetery where we have a family grave, great for that at home I have used a heater a few times with it but it’s not as good as from the mains socket not as much heat output, now I don’t know if this is down to the lower voltage as using V2L you aren’t getting the same as the grid which is around 237-242 at my home but from V2L that is more around 216 -220 volts so a little lower so the heater does not get quite as hot, one day I ran a 1kw heater for 4 hours which was cycling on its thermostat and the battery percentage in the car reduced by around 10% I used a energy monitoring smart plug to get some of the measurements on voltages, and the heater on the mains was drawing about 1084 watts where from the car it was only drawing about 945-960 watts.
The other thing is the limit of load you can put on the V2L officially i believe it is rated at 2.5kw where a home battery can be double or more than that I know some on YouTube have shown way over the 2.5kw being pulled from the V2L but I wouldn’t risk that for any length of time to be honest but it’s good to have it works but with some limitations.
But I’m still experimenting with it.
Les
I used the V2L and monitored it, found the car used so much power to convert the DC from the battery to AC for the home that at the end of the day there was almost no saving, even having charged the car on Octopus GO at 9p per kWh my power bill for February was almost the same as last year.
Absolutely not worth it. but OK for occasional power usage.
Its a lovely feeling when all the lights go out except yours (engage smug factor)
I have had a few tests of my system over the last two years.
2x Tesla powerwall provides approx 27kWh of energy back up (provided they are fully charged).
On occassions I have seen over 5.3kW coming off the solar panels and that's in sunny West Wales.
I am now looking at the idea of a water turbine and a windmill!
