Well my drivers outer door handle has started sticking /not returning back when let cgo causing it to keep latch open
Any one else had this ?
Ps 2021 MG5
Ps 2021 MG5
You could try using some silicone spray.
I've done this a couple of times over the last 3 years... takes a minute or so and the handle is fine for ages...You could try using some silicone spray.
It will be fine until the cold weather returns, then it will stick again for sure.Still ain't sprayed it but since the weather has warmed up it's not doing it
I jumped on my wife's MG5 the other day and pulled away and the door pinged open. The handle had stuck out so the door wouldn't latch closed.Should it be covered by warranty?
I read somewhere that an advisory had been put out re MG door locks.
