Haricot
It seems to clear after restarting the carIn your position I'd do the same. In my case I've rarely ever had an AH fault, when I have it has cleared very quickly and not come back.
At least if you have to (or want to) use the EPB it self releases when you pull away. Just don't pull away too quickly otherwise it can go with quite a clonk.Give the regular "Auto hold fault" message I get, I don't trust AH & manually apply EPB every time. Going to the dealer for investigation very soon
I think it really refers to the EPB with AutoHold.Just to muddy the waters I think there is a typo in a bit of the manual pictured earlier:
"Auto hold cannot guarantee the electronic
parking brake operation in all cases where
the power system is turned off. Please
ensure the electronic parking brake is
applied and the vehicle is stablised prior to
exiting the vehicle."
Should (I think) read:
"Auto hold cannot guarantee the brake operation in all cases where
the power system is turned off. .... "
When you apply the EPB manually you hear a small motor whir for a second, I assume doing the same thing as pulling up a regular handbrake. I can't hear this when when auto hold activates and think a small amount of 12V is required to keep the brake on for the duration of autohold. Hence their reference to the case where the power system is turned off.
You need to select neutral if you need to push the car.I seriously have no idea why N even exist in this car...
My driving instructor taught me to use the handbrake (or its modern equivalent, the EPB) as per the highway code and out of consideration for other road users. At night I consider the glare of stop lights, particularly LED ones, is both irritating and unnecessary.I've highlighted the key word ... it's not a must so it's merely an advisory.![]()
As a matter of interest, have you driven or owned an automatic ?My driving instructor taught me to use the handbrake (or its modern equivalent, the EPB) as per the highway code and out of consideration for other road users. At night I consider the glare of stop lights, particularly LED ones, is both irritating and unnecessary.
Going through a car wash that drags you along. Eg an imoI seriously have no idea why N even exist in this car...
Yes, I bought a BMW 120d auto in 2006 and reluctantly sold it last year due to ULEZ. I'd previously owned a Passat estate and wanted an EV with similar flexibility. In spring 2023 only 2 EV estates were on the market: a Taycan (£80k+) and the MG5; I chose the latter! Why do you ask?As a matter of interest, have you driven or owned an automatic ?
Just wondered if you put the automatic car in park or neutral every time you stopped. Although fine in an EV, leaving an ICE in D with the handbrake on puts a strain on an automatic gearbox with a torque converter.Yes, I bought a BMW 120d auto in 2006 and reluctantly sold it last year due to ULEZ. I'd previously owned a Passat estate and wanted an EV with similar flexibility. In spring 2023 only 2 EV estates were on the market: a Taycan (£80k+) and the MG5; I chose the latter! Why do you ask?
That's one of the things that I particularly do like about the MG4. ?I don't understand why MG have opted to emulate the undesirable ICE auto creep in their EVs.
and don't over think itAuto hold, every time
Hi, You don't quote what make or type of car you've got, but obviously you've only changed over to Automatic from Manual by asking this question. Remember that MG comes from China. Some China Manufacturers, the way they quote in English to explain instructions, can become some what confusing. On a MG EV its in D while driving. When stopped on a hill, it has an automatic hold as long as you keep put your foot on your brake all the time you've stopped , and then change over to accelerate off within a FEW seconds. If not the car WILL roll backwards.On common automatic transmission, and stopping at traffic red lights ive heard 2 versions...
1) change to Neutral to wait for green lights so that the transmission is not trying to push forward unnecessarily.
2) stay in Drive and step on the brake. So you keep the transmission in place and dont make changes unnecessarily.
And then i see this in the manual:
Which makes me wonder...
Whats the best practice to maintain this car on good shape?
1) change to neutral + use emergency brake in hills (that electric brake right of the shift knob - its called EPB i think? )
wait for green, shift to drive and release EPBs...
Sounds more steps to do
2) stay in drive, and step on the brake to activate Auto Hold and release pedals.
wait until green, step on pedal and go >> my favorite option and this is what im doing....
But after reading the manual... Im not sure if im doing the right thing.
What are you guys doing in red lights?
Example: auto hold will not operate in reverse, but Hill hold assist will, and stay on for several secondsHi, You don't quote what make or type of car you've got, but obviously you've only changed over to Automatic from Manual by asking this question. Remember that MG comes from China. Some China Manufacturers, the way they quote in English to explain instructions, can become some what confusing. On a MG EV its in D while driving. When stopped on a hill, it has an automatic hold as long as you keep put your foot on your brake all the time you've stopped , and then change over to accelerate off within a FEW seconds. If not the car WILL roll backwards.
Kind Regards
