Tyre pressure monitor
Amun
Norfolk, UK
In the manual it says :-
Note: After changing the tyre position or replacing a TPMS sensor and receiver, the vehicle needs to run at a speed of 25mph for about 10 minutes to correctly indicate the tyre pressure value at the corresponding position.
Has anyone tried this out? So far I haven't had to replace a tyre, but it will happen one day.
As far as I remember you try this every day you use the car. Switch on and check the TPMS readings - no results. Drive for a while and then it does.
Upvote 0
I rotated my wheels front to back and I don’t think it’s learned the new positions. Not a problem as I know where each tyre actually is
Upvote 0
