Running at 2.9 Bar over the recommended 2.8 Bar is likely to make very little difference TBH.
This is not massively over inflated, in fact you could have set the pressure to 2.8 Bar and then that thing they call "The Sun" makes a brief appearance.
The pressures in the tyres facing the sun, will have likely increased to 2.9 Bar anyway !.
It is not unusual for manufactures to increase tyre pressure a lot when carrying out efficiency / MPG testing and EV's also I guess ? .
Of course, this practice is not suitable / safe for general road use, as it makes the ride extremely hard and both the traction and braking efficiency will be compromised as the full width of the tread pattern is not in full contact with the road.
Wheel spin is more evident in FWD cars and rain water is not displaced as well also.
Of course this is in extreme cases.
This screen shot has been taken from the Bridgestone web site.
Overinflated tyres
When it comes to tyres and air, there’s also the ‘too much of a good thing’ factor. In overinflated tyres, the sidewalls and tread become harder than normal and the contact patch of the tyre on the road shrinks. This change in footprint can reduce traction and performance, giving you a bouncy ride and affecting the handling of the car. Over-inflation will also cause uneven wear thereby decreasing the life of your tyres.
