Unblock rear window washer
admiralross2400
Musselburgh
Anyone know how to check and unblock the rear window washer? I know it's in the bit that holds the blade but can't see an easy way to get at it.
It's no longer squirting but the pump sounds like it's trying.
It's above freezing now so I don't think it's just frozen any more.
Where did you locate the tube please? I have the same issue and can’t seem to locate the nozzle or the hose.
Any help greatly appreciated
Basically, pop off the panels in the hand holds of the boot, unscrew the screws then pull the plastic cover off. You should see it in there
